There are many Anti-Virus programs available these days. Some say that Avast is the best Anti-Virus while some of them award the best title to AVG. Which is the best Anti-Virus in terms of system security? What are the features to look forward to in the best Anti-Virus Software? Any suggestions?
Which is the best Antivirus Software? Any suggestions
There are several antivirus products that beat Kaspersky and Viper is one of them. It has excellent quality of real-time antivirus, manual virus scanning and also USB virus scanning.It is easy to install and great tech support. It has very good resource usage. In Kaspersky sometimes you have to face slow speed in your PC or laptops, but Viper does not decrease your speed. So, you can try this.
Hi, Joseph D Saunders the best antivirus it’s not the award that it gets but the ability to do the task necessary for the security of your unit. Kasperky is a professional choice. Â
This is why I recommend Kaspesky compare to others
·        Antivirus protection
·        Cloud-assisted technology enables real-time protection
·        Preventing the exploitation of software vulnerabilities
·        Protection against screen lockers
·        Efficient updates for antivirus databases
·        URL Advisor
·        File Advisor
·        Anti-phising protection
·        System Watcher
·        Minimal Consumption of PC resources
·        Rapid start-up, shutdown and reaction times
·        Longer battery life
·        Optimised for Windows
·        Improved user interface
·        Streamlined settings
·        Automatic upgrades
·        Improved virus scan features
