Which is the best Antivirus spf
Windows 8 appears to be a radically different experience and environment for PC users, just like it has proven quite different for software developers. Having that in mind, you’ll likely need to get an updated antivirus software to keep your computer safe and protected against harmful viruses. There are many antivirus softwares to choose from and are available but the one thats on top of the list is Bitdefender. Watch this video for the complete instructions
Hi Raquel C Mitchell,
There is antivirus software in windows 8 already. Its name is Windows Defender. In older version (Windows 7, Windows XP, Windows Vista…), that is Microsoft Windows Essential. Open Control Panel, type “defender” in search box, you will see it in the first line. Right-click on this > Create shortcut, you will create a shortcut for this program on your desktop. You need to update this program as often as possible, and use it regularly.
Hope this helps
