Hello Techyv Experts, I am in search of the best Arabic search engine. Please help me to find the best Arabic search engine that will work without having an Arabic keyboard, means I can enter the text as I pronounce it in English. Please suggest me the best search engine that will give best results. Thanks
majdman
Which is the best Arabic search engine
Hello Janetsbraswell,
You can't really determine the 'best' search engine, but based on the amount of satisfied customers, I think just sticking with Google is the way to go. Here is a link to the arabic version of Google ( Hosted by Google of course)
https://www.google.com/webhp?hl=ar
If you have any further question feel free to ask me, otherwise, have a nice day!
I found a really good and popular search engine called Yamli. This search engine is powered by Google, but it is made just for the Arabic language. It also supports a smart keyboard. Smart keyboard means that you type using Latin letters but it suggests to you some Arabic letters. I hope I helped. Regards.
