ave broers
70 points
Posted on - 11/21/2014
I am searching for a cleaning app for android. I want it for cleaning and removing unnecessary data from my mobile and keep mobile space free and clean. Can anyone suggest me with a best cleaning app which would be free or least affordable for my android device. Please help to take a decision.Â
Which is the best cleaning App for daily usage?
Hi.
In my opinion the best cleaning app will be clean master. I use it myself. This has very useful options like clean junk files which helps you clean unnecessary chat logs. It has app manager better than android default one. It has a memory boost option in 3 cool ways.TRUST me, close your eyes and download it and if you like it, then I am to blame.
If you are looking for an app that will help you make your Android device tidy, you can install Clean Master to help optimize the performance of your device. Among its features include Junk Cleaner, free antivirus, Private Photo, Wi-Fi Security, Boost Mobile, and Battery Saver. With Junk Cleaner, the app helps you free up some space by removing leftover and cache files.
It is one of the best and known optimization tools for mobile devices which also include a free antivirus. It can clean your device from junk files and improve its performance by freeing up RAM. You can also perform a speed test to see how fast it is than before. It also includes a Charge Master feature which protects a device from overcharging.
With Boost Mobile, the app helps you enhance the performance of your device by freeing up RAM. The Battery Saver feature helps you prolong the life of your battery by hibernating running applications. See if this improves the performance of your device. If you think your Android device is still slow, restart your device. This is the easiest way to refresh the memory of your device.
If you want to keep your device running at good speed, always make sure applications are closed properly. After using an app, when you close it, check the task manager to make sure it exits completely. On Android, sometimes when you close an app, it doesn’t close completely. It just goes to the background and will remain running until you open it again.
Unfortunately, after checking the link above, I learned that it is no longer reachable. After a little searching, I located the website of the original Clean Master but to my surprise, they are no longer supporting Android and instead focusing on Windows PC. If you want to try it on your computer, you can download the free version from the Clean Master home page.
Alternatively, for Android, try the Clean Master app from Cheetah Mobile. Another app you can try is Speed Booster. The latest version at the moment, Speed Booster 11.55.38, requires Android 4.1 Jelly Bean and higher. Before downloading any app, check the user feedback first to learn some of the usual problems you might encounter.
