Hey guys,
Please tell me which is the best download accelerator for Windows 8.1 PC. The problem is my Pc is slow and also I can see that downloading of software also effected due to this for which I want to download a download accelerator so that I can download at a fast speed. Please suggest me.
points
Which is the best download accelerator for PC?
Downloading files from the web depends on the speed of your internet connection. If the connection is slow, there’s no chance of getting faster speed even you’re using the best algorithm to download your files.
However, you should make sure that your PC’s performance is on the top. You can use CCleaner, Wise Care 365 etc. to clean-up your Windows 8.1 and make its speed like a Lamborghini Diablo Coatl.
You can use the best download manager all over the world that could make your file downloading speed a little bit faster. Internet Download Manager is the best of the best, and the price is quite reasonable. I’ve been using and got tremendous speed in downloading movies, programs and other files.
