abigail.era
Posted on - 12/02/2012
I'm confused with footer slider logos jquery software. How can I find the best software in this regard? Please, give me a link from where I can download the software free of cost. Is it possible?
Thanks
Which is the best footer slider logos jQuery software?
Hello!
There are many websites where you can download this software. You can do well if you use this software. It will be easy for you to solve various sliding problems. I will share with you this link:
http://soft.udm4.com/downloading/logos_footer_slider_jquery/
You can can get from that link “jQuery Menu Slide Style 09”, “jQuery Gallery Slider Generator” and many other codes. Best of luck.
There are several jquery sliders available for footer. The best software the i found was jquery menu slider 09. You get Jquery menu slider 09 from here http://soft.udm4.com/Web-Authoring/jQuery_Menu_Slide_Style_09.html . It is very good in terms of productivity and you will also get free of cost, yes it is a free software.
I hope this helps you solve your problem.
Peter franklin
Well explained Perry Deborah and Peter Franklin. Peter Franklin, the link you provided is excellent. It is the easiest way to add stylish rollover menus to my website and for that I do not need to know about web design and it is free as I expected. Thanks Peter Franklin for your valuable advice.
