Hello, TechyV experts!Â
I am using Mac Pro and I have to use Photoshop. Actually, I am a graphic designer. Besides designing, I have to edit different types of images and documents. I need the best free Mac PSD editor for my Mac Pro. Please anyone help me to choose best free Mac post editor.
Which is the best free Mac psd editor?
Hi Gary V Lindgren,
Alternative for Photoshop on Mac OS? There are apps that I'll give you so that you can edit your PSD files on Mac.
Please visit this site so that you will see the list of apps alternative for Photoshop on Mac OS.
Each of the software is free and they provide a description of the software for you to decide what to choose. Click this link to view the top alternative for Photoshop.
Hi there Gary V Lindgren,
PSD is an Adobe Photoshop specific extensions used to save files that should be used in one of the Adobe Creative Suite components. You can eventually try opening and editing PSD files using GIMP editor, but I wouldn't suggest you to do so as it can mess up your PSD document badly, just as any other editors that are able to open PSD files.
Photoshop is available for Mac OSx just as for the Windows platform and I would suggest you to either convert your files to something less specific than PSD or to stick with Photoshop on your MAC OSx.
Best regards,
Drake Vivian
