Which is the best Macbook cleaner?
Hi everyone,
I purchased this Macbook few months ago and I use it everyday in fact all my time, I keep using it and download many files and videos. So i want to clean my Macbook to remove un necessary files and videos to make my Macbook faster like before. So please tell me any good optimiser an cleaner for it.
Answered By points N/A #187478
If you download files and videos from internet, it means that you might be downloading important files. Downloading the large files would generate a large number of junk system files which can be cleared. But the files you’ve downloaded manually need to be deleted manually by yourself.
In order to make your Mac free from junk files, you can use Speed-Up-Mac. This tool is a nice one, removing unnecessary entries from your Mac and powerful enough to boost up performance.
CCleaner is also available for Mac OS X. It’s one of the best cleaning tools for both PC and Mac.
