Hello! I am using Mac operating system and I have several notes in my machine. I gave a friend of mine the computer and he did something with thereby encrypting all my notes. Anyone with a notes encryption remover that I can use to remove the encryption? The problem here is that I do not know what kind of encryption was used since I do not even have an encryption software installed.
Which is the best note encryption remover for Mac OS?
Hi Dorothy C Hoskin,
Thanks for choosing us to get help.
The encryption and decryption tools are available in some versions of MAC operating system.
You can use these software utilities without any difficulty.
But if you want to use software to remove encryption then I have an idea for you.
First of all, please make a pdf file and copy all encrypted notes in this file and then use PDF Encryption remover.
This software is designed specially for MAC.
You can download this software here.
Download Best PDF Encryption Remover for MAC.
ThanksÂ
