Which the best program to merge partitions?
I need best program to merge partitions because the size of my partitions is too much small I am unable to store large program whose size is in GB for example office 2007 whose size is in GB.
I don’t have enough space to install it in C drive so I want to merge the partition so that I will be able to install the MS office 2007 in it.
Answered By 0 points N/A #159545
Hi Aldofojeremiah,
There are several websites from where you can download this partition software from.
The best application that I have also personally used is partition magic.
Partition magic Partition Magic allows you to create, format, resize and merge partitions.
However,you must be careful while using this software because you can format wrong partitions that contain vital files.
For free download you can visit this site
After downloading and installing your computer.  A shortcut will be created on your desktop which you can use to access the application. You can then resize the partitions the way that you like.
I hope this help you.
Henry.
