I need protected DVD maker software for the safety of my confidential DVD’s. Is there any paid version or trial version protected DVD maker,can someone suggest me the best available software for this purpose?
Which is the best protected dvd maker software?
Hi Steve
I wanted to answer you concerning the DVD make, there are a variety of Good DVD makers that you can use to you satisfaction but i will recommend that you use the Xilisoft DVD creator which is usually very easy to use and which lets you completely modify and convert the end result. The software provides you all the selections to burn accurately the DVD you like. The DVD can be created or converted from DivX, AVI, MPEG, XviD, MP4 or AVC/H.264,WMV formats and many others. Also it has a supported conversion process, which gives you the versatility in creating high definition DVDs.download and enjoy there is a free download and a paid version of it.Seach download and enjoy.
Thanks
Hi Steven Tanner,
There are two things that you have to do when you are putting some files on your DVD, when you insert the DVD on your disk drive, you have options on how you treat the DVD, there is a burn or it can act as USB, from then, choose the Burn method of treating the disk, at this point, burning something on a DVD is like putting some tattoo on your skin that you can not remove it easily. Your files will be protected enough and cannot be stolen from you.
To Answer your questions the best way to protect information in the DVD is encrypting before writing that will make sure you have the sole ownership. For that you can use Truecrypt and that can help. For bigger and quality output you can use ProtectBurn software which is easy to use and its tested by most leading studiosÂ
