Hello, I need 20 routers to install in a big location. Each router needs to cover an area of about 50 square meters. Some of them need to be installed outdoor as well. I am looking for suggestions for some good routers that are reliable and can throw WiFi signals to a long range as well. Which are some good router companies besides CISCO? Please also guide me about which will be the most suitable router?
Which is the best router for long range and reliability?
There are plenty of long range capable routers and promise to deliver reliable service and connectivity. Some of the names are DLink, Netgear and other brands that manufacture mobile phones as well. To best suit your needs, you may try scouting at Amazon.com and the likes. In there, you could right away see the prices and the specifications. If you found what you like that best suited your requirements, you should make a more detailed researching by going to its official web site. Afterwards, you could now decide buying the device from a trusted dealer near you or through the internet.
