Which is best? An Ultrabook or an Apple Macbook Pro?
Hello! If you compare the two the Ultrabook and the Apple Mac Book Air we know that the Air is the first to be launched and ultrabook has adapt some of the features of the Air even the price the storage and etc. This two has almost the same features so it really is up to you what to choose the Air is light but so as the ultrabook. But Air doesn’t run Windows 7 if you want something that with Windows 7 then you better not choose Air but if its okay with you without it then enjoy Apple Mac Air and not Ultrabook both is light, high quality, fast to start and beautifully built. So you yourself alone will do the verdict of choosing the right gadget for you huh? Check out the two on this picture and compare.
