Which is the best writing software for Mac operating system?
Hello writer! I am using a mac platform for my writing. All along I have been using the in-built applications for my writing work. I would like to get the best writing software for mac that I can use for my projects. I need an application that will cost me not more than $50 and it should be one that I can purchase and download without having to wait for the CD.
Answered By 30 points N/A #199413
The writing software are of much variety for all windows and operating systems.
You can use Note pad for MAC for writing purpose.
But note pad will allow you to just write the text, you will not able to put images into writing.
I suggest you to use Microsoft Word for MAC.
Microsoft has developed WORD for MAC operating system on very cheap cost.
You can download the Microsoft word for MAC from this link.
It will make you able to put images as well as graphs and charts.
Thanks
