Which is Better to buy? Intel or AMD?
Greetings Daisy! Upon reading your question here’s I’ll be giving you my opinion. So based on my Experience as a I.T Support, in terms of budget wise i would choose AMD because it’s much cheaper, it is also has a good performance, and i can say is it has most of the Intel Processor features and capabilities.
But in terms of Durability in my experience Intel has Dominated the AMD, because Intel is very quiet, the temperature doesn’t easily goes up, and even you use your computer 24 hours a day the temperature will still be nearly the same. Unlike AMD that has some Overheating Issues. Well that’s only my Opinion the final decision is still in your hands.
Hope this answer helps you, have a nice day!
Hello Daisy Lazaro,
Intel generally makes faster processors than AMD, but AMD chips are generally cheaper for the same specifications. For example, the AMD Opteron 6272 costs around $540 but the comparable Intel Core i7 980X costs $1,000. The 980X is an expensive chip though and there are faster, cheaper Intel CPUs.
So, I suggest you buy Intel.
Hello Daisy,
Like almost everything Intel and AMD both have some pros and cons. So it’s useless to praise for intel or ADM separately. But if you can bear the price, go for Intel.
Good Luck Daisy Lazaro!
Notifications
