Which is better: C# or C++?
I am interested in learning the programming languages. Can anyone tell me which is better: C# or C++?
Basically C# has more advantage than using C/C++. But it also depends on what project are you going to work with. C# is more likely use in some desktop applications or windows software, but if you are more in gaming you have to choose C/C++.
So it depends on what type of programmer you are. You can also notice the difference of them if you are going to try to use both of them.
Sometimes you can only understand something if you are going to work with it. So try to use both of them, they are very useful. But if you want to know it by your self, it will take some time to realize which is better.
Thank you for that analytical question Mr. Ryan. We will first know of what is the difference between C++ and C#. C++ is one that gives core functionality and custom resource management while C# is one that conforms to the OOP standard and better in terms of visualization.
So the question now is what is better between the two. C# is very essential for main knowledge on the programming structure but C++ will help you understand more on what really happens under the sun.
So it is better to learn both of the two to be able to structure your work well.
So the answer is C# is easier because it conforms to OOP while C++ is more beneficial and powerful because you can customarily manage resources.Â
I hope this will help you.
Hi Ryan AbateÂ
Check out another Techyv post which is also described according to your question. Visit this page and enrich your knowledge.
