Which is better – Disk doctor Mac vs Ccleaner 2012?
Hi guys,
I'm using Ccleaner on my MAC PC. I heard about Disk doctor which is much better than this. Which will you recommend? Disk doctor Mac vs Ccleaner 2012?
Hi guys,
Hi Harden,
Well Ccleaner is and has to be the widely used utility for cleaning junk files. It is popular for it's third party add ons. It cleans junk files from 270 applications and it is supportive to html5 and thus helps in DB cleaning management for chrome, firefox, safari and others. But one drawback this utility has is it cant clean junk files from prefetch and C:UsersusernameAppDataLocalTemp folder.
On the other hand disk doctor has a very limited disk scan priority so it would clean lot less junk files from your PC or laptop if you have 250 GB of disk space it only cleans 650 MB which is roughly 1% so you don't get a lot out of it.Â
In my opinion Ccleaner would be the best
Thank you
