I wanted to know which one is better between iPad 2 and Android device as both are popular and available widely. I am really confused about the performance. That is why, I am seeking an advice from an expert.Â
On what android device you want to compare with iPad2? Anyways we will compare iPad2 to Asus Eee Pad Transformer Prime. Let me give you a breakdown:
iPad2Â specs:
A5Â 1 GHz dual-core processor
IOSÂ 4.3 operating system
Display: 1024x768px resolution
Weight: 1.3lbs
Battery life: 10 hours
Camera: 0.3MP VGA front-facing camera and 5MP rear-facing camera
Network: 3GÂ UMTS/HSDPA/HSUPA, GSM/EDGE, CDMAÂ EV-DOÂ Rev. A
Built in speaker
Connectivity: WiFi (802.11a/b/g/) Bluetooth 2.1+EDR technology, 30-pin dock connector port, 3.5mm stereo headphone minijack, Dock connector to USB cable, HDMI.
The Apple iPad 2 is available in two models: Wi-Fi and Wi-Fi + 3G. The Apple iPad 2 Wi-Fi + 3G is a 3G tablet operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public and released on March 2011 measuring 241.2 x 185.7 x 8.8 millimeters and weighing 607 grams.
It uses micro-SIM card and has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 768 x 1024 pixels screen resolution. It supports multi-touch protected by scratch-resistant glass with oleophobic coating. It runs on iOS 4 upgradable to iOS 8.3 powered by Apple A5 chipset, 1.0 GHz Dual-Core Cortex-A9 processor, and PowerVR SGX543MP2 GPU. It doesn’t support microSD.
It runs on 512 MB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 0.7 megapixel at 960 x 720 pixels screen resolution. It supports 720p video recording at 30 fps. The secondary camera supports VGA. It has 3.5-millimeter jack, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS support, USB 2.0, and Wi-Fi 802.11 a/b/g/n with dual-band support.
It has built-in accelerometer, compass, and gyro sensors. The pre-installed Safari browser supports HTML. Java is not supported. It runs on non-removable (25 Wh) Li-Po 6930 mAh battery with standby time up to 720 hours and talk time up to 9 hours.
1....
