Most of my friends are addictive to iPhone 6 but I think that after the release of Samsung Galaxy S6 Edge, it will be in the top of list of Smartphones due to it's features. Are there more features in Samsung Galaxy S6 than in iPhone 6? Will it be more successful than iPhone 6?
Which is better? iphone 6 or Samsung Galaxy S6 edge.
If you compare the design of Samsung Galaxy S6 Edge and iPhone you will found that S6 is 6.9mm thick, body is made up of aluminium and glass panel. However iPhone is 6.9mm thick as same of S6 and aluminium back. Screen of both phones are S6 is 5.1 inch, 2K Super AMOLED and iPhone is 4.7 inch, 1334*750 IPS LCD. Processors are S6 having 64 bit Octa core and iPhone having 64 bit Dual core 1.4 GHz. The RAM is vary in both of them S6 having 3 GB while iPhone having 1 GB RAM. The camera difference is also there S6 having 16 MP rear and 5 MP front camera. iPhone having 8 MP Camera.
The latest Smartphone in the Samsung Galaxy S series is the Samsung Galaxy S8 Active. The Samsung Galaxy S8 Active is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled and released on August 2017 measuring 151.9 x 74.9 x 9.9 millimeters and weighing 208.1 grams.
It has a Corning Gorilla Glass 5 back panel and uses nano-SIM card. The Smartphone is IP68 certified (dust proof and water proof over 1.5 meters for 30 minutes) and MIL-STD-810G compliant (salt, dust, humidity, rain, vibration, solar radiation, transport, and thermal shock resistant) and offers Samsung Pay (Visa and MasterCard certified). It has Super AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution.
It supports multi-touch protected by Corning Gorilla Glass 5 featuring 3D Touch (home button only), Always-on display, and TouchWiz UI. It runs on Android 7.0 Nougat powered by Qualcomm MSM8998 Snapdragon 835 chipset, Octa-Core processor (4 x 2.35 GHz Kryo and 4 x 1.9 GHz Kryo), and Adreno 540 GPU. It supports microSD expandable up to 256 GB. It runs on 4 GB RAM with 64 GB internal storage.
The primary camera supports 12 megapixels with f/1.7, 26mm, phase detection autofocus, OIS, and LED flash featuring 1/2.5″ sensor size, 1.4 µm pixel size, touch focus, face and smile detection, auto HDR, geo-tagging, simultaneous 4K video and 9MP image recording, and panorama. It supports 2160p video recording at 30 fps and 1080p at 60 fps with HDR and dual-video rec.
The secondary camera supports 8 megapixels with f/1.7 and autofocus and supports 1440p video recording at 30 fps with dual video call and auto HDR. It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 5.1 with A2DP, LE, and aptX support; GPS with A-GPS, GLONASS, and GALILEO support; and USB Type-C 1.0 reversible connector.
It doesn’t have FM radio. It has built-in iris scanner, fingerprint (rear-mounted), accelerometer, gyro, proximity, compass, and heart rate sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on non-removable Li-Ion 4000 mAh battery with standby time up to 120 hours on 3G and talk time up to 32 hours on 3G. It is available in tungsten gold and meteor gray colors.
1....
