My friend has a IPhone but I don't have any Smartphone. I also want to buy a phone. But I am not able to decide whether to buy a IPhone or a Smartphone. Please help me decide to choose between these two phones with their features,functions and capabilities. Does these Phones have any negative sides too?
Which is better IPhone or Smartphone?
iPhone is run by iOS and generally, smartphones are run by Android OS. Both of them are great but depending on your usage, you should choose different one.
Android is the most popular mobile OS now a days, and so Android-enabled smartphones are. It’s because of its open-source platform, better performance, lots of apps in its store and super simplicity. On the other hand, iOS is managed by Apple, which is not open source and its development isn’t so enhanced like Android.
If you look for better gaming performance, Android is highly recommended. If you’re concerned about security, iPhone should be your choice.
The most annoying part of iPhone is, it requires jail breaking which is illegal to run in some region where Android dominates the entire world. I recommend having Android smartphone but if you prefer iPhone, you can have it.
