Which is better MacBook Pro with Retina display or MacBook Air
My friend loves her MacBook Air, but when she saw MacBook Pro with Retina display, she was very excited about it and could not wait for its release. I wonder which one is better?
How does the MacBook Pro with Retina display's hardware, software, and system differs with MacBook Air's?
Best Answer by Crizda Bilano
Answered By 0 points N/A #161192
If you compare the two products of MacBook the Air and the Retina Display in a quick look you could say that there is no difference between the two. But in a closer observation you will find out the few difference that of the two products. You will see at a closer look that the other one is thinner than the other one; you will also observe the absence of the presence of the optical drive spot. On the other hand the New Pro is more heavy than the Air. Its speaker is has a sophisticated speaker and volume compared to the old Pro. The display of this retina Display is amazing even the video images. All in all the retina display is a little improvement of the MacBook Pro in the end it will be your decision on what to choose since the two is at its higher performance level and gives out satisfaction to the consumers need.
Answered By 70 points N/A #161193
My friend wants to buy a MacBook, and he asked me if MacBook Air is better or MacBook Pro is. I didn’t know much about them so I tried to find a good answer online and i found it here. Thank u sir for pointing out the differences….now i can tell my friend which is better for him. Thank you very much
