Which is better, New Samsung Galaxy S6 edge or LG G4?
The latest release of both of these companies has just made a huge achievement in the market of smartphone. Both smartphones have the best software’s and hardware’s assembled in it which is available in the market. But, which is the better among these two by the overall design of the phones?
Answered By 0 points N/A #185502
LG G4 has 5.5 inch IPS LCD technology with 1440*2560 pixels and 538 ppi while Samsung Galaxy S6 edge has 5.1 inch Super AMOLED screen with 1440*2560 pixel and 577 ppi which means S6 edge has a better image sharpness compared to LG G4 though it would be really hard to compare the difference between the images.
Both have 16 MP back camera so doesn’t make big difference but LG G4 has 8 MP front camera while s6 edge has only 5MP which means video calling would be much better on LG G4.
Samsung has octacore 2.1 GHz processor while LG G4 has 1.8 Ghz Hexacore processor both have somewhat similar graphic chipsets. Samsung gives better performance.
LG G4 has a 3000 mAh battery compared to 2600 mAh of Samsung s6 edge.Samsung s6 edge a better battery life compared to LG G4 cause LG has a bigger screen so it uses more battery life compared to s6 edge.
Other all features are somewhat same. LG G4 has memory card slot and S6 edge doesn’t but LG G4 comes in 32 gb internal storage while s6 edge comes in 32/64/128 GB.
Performance wise S6 edge has and upper hand but it is a slight difference you won’t be able to know unless you make both devices run with a heavy game or something.
I would prefer S6 edge with AMOLED screen and octacore processor which will give better performance when it comes to gaming.
