Most of my friends suggest me to buy Samsung  Galaxy S4 but I think Black Berry leap is also a competitor to Samsung Galaxy S4. Which is better regarding everything from looks to it's performance. Is it wiser to buy a Black Berry leap or should I buy a Samsung Galaxy S4?
Which is better, Samsung Galaxy S4 or Black Berry leap?
Both are amazing devices, But i would recommend you to go with the Samsung galaxy S4, Spec wise, Both devices are pretty much the same, But the Samsung galaxy s4's screen is superamoled, Which puts the Blackberry leap's screen to shame, Also the S4 is lighter, And has higher screen to body ratio, Which means less bezels, Also Android is much better than Blackberry OS, You can get customizations on Android that you can only dream of on blackberry OS.
