Which is a better tablet? iPad or eee asus tablet?
Which is a better tablet? iPad or eee Asus tablet? Compare Android eee from Asus and iPad 2 from Apple.
I think it all matters depending on your needs or likes. It's for you to decide if the IP ad tablet suits your needs or the Eee Asus tablet depending on their features and affordability.Â
IPad Tablet | Eee Asus Tablet |
DESIGN
DESIGN
DISPLAY
DISPLAY
CAMERA
CAMERA
PROCESSOR
PROCESSOR
SOFTWARE
SOFTWAREÂ
CONNECTIVITY
CONNECTIVITY
IPad and Eee Asus are the best technology no doubt and they create tremendous changes in a technological society. In my opinion Eee Asus tablet are the best in comparison to iPad as it is featured powerful and appealing for keyboard dock which turns it into full fledged android powered netbook. We can compare both with different aspects.
Appearance:
IPads are slim and require high end material impressions as it is made of Aluminium uni-body design. The case is also thick.
Android Eee Asus is made up of plastic back shell thus we don't require high impression and fairly scratch resistance due to the roughened texture. It displays bezel due to combination of bronze and brown in terms of color. The edges are of Aluminium and over all it is a high quality device and it allows image changes on moderate pressure.
Connection:
IPad allows an SD card reader and USB port via docking connector and has the limited functions majority of pictures and digital cameras, it has also a low internal memory.
Android has standard connectivity and supplies a docking port, a microphone socket, a Micro slot and its own slim HDMI post.
Configuration:
IPad requires iTunes for all functions to transfer pictures from a digital camera, while Asus Eee tab successful recharge via USB is also not possible and is detected as a mass memory unit and data sharing is easily accomplished.
So now the choice is yours!
The Asus Eee Pad Transformer TK101 is better than the IPad Tablet because it is comfortable to use especially reading e-books and it holds from any position. The Eee Tablet glossy touchscreen and an extraordinarily thick black bezel with curved gray sides are easy to use than the IPad Tablet. The IPad tablet was designed to minimize fingerprints and the wide black bezel surrounding its oleophobic display but oil-resistant.
The IPad tablet was too heavy to hold in both hands for a very long time and covered with smudge marks. The Asus Eee Tablet and Apple IPad Tablet have almost the same qualities but I prefer to use Asus Eee Pad Transformer because it is more affordable and easier to use than the Apple iPad.
This Asus Eee Pad Transformer tablet is so much better the original iPad and iPad 2, I have had the use of all three and I would never get a second iPad even if it was free. This tablet is so easy to use, costs less and has many more features.
Also it runs Flash which is a real must if using this to surf the net, unlike the IPad. The feel is comfortable especially reading e-books. You can use the included USB cable to copy music, video and any other types of files you wish to the Transformer. No need the keyboard dock to do that.
