Which cable will I need
My computer have HD15 VGA socket and my Plasma TV has an HDMI socket.
How to connect. I tried finding it on cables' web sites, but could not find anything.
Please help.
Please help.
Hi Silver Joson,
Well, do not worry anymore; your problem is an easy one. You just need a certain cable to connect your Plasma television to your computer. Well, in your case, an HD15 is simply another name of a VGA connector. It has a numerical input of 15 since it has 15 pins located in its connector. Your Plasma television probably has a female VGA output, and has a female HDMI output. Since you also have a female VGA output in your computer, I suggest you buy a male to male VGA connector. Besides that, you could also buy a male VGA to male HDMI connector.
Hope this helps.
>>Mathew Joni<<
