Which camera record avi file automatically? There are some camera that doesn’t support avi files and still needs a converter before we can render an avi file. But I think there are some camera with a software that supports avi files. Would you give me some knowledge about this matter?
Stephen Heris.
Don’t use Casio, Olympus, Panasonic Lumix, and Kodak Easyshare since the video they produce are in .mov format. I suggest that you use Canon digital cameras, Nikon Coolpix, Fuji Finepix digital cameras, and Samsung digital cameras. They all record MPEG 4 videos in .avi format or .avi file extension. I hope this helps.
Hi Stephen Heris
Hope you are fine. AT first you need to know that .avi is the only format which developed by Microsoft. You can convert any recorded video to .avi via lots of video converter software. I didn’t get any automatically .avi recorded camera but canon can help you a lot perhaps Canon is better from Nikon or Pentax. In your question, there are numbers of brand which could work. Canon cameras record video in .avi format. It records M-JPEG to .avi automatically. Brand name is Canon G9.Nikon Coolpix, Fujii Finepix, Samsung digital camera also record video in .avi format.I hop this will help you.
With Thanks
Greaney Mary
Hi Hodge,
You can get it for free to download from mac.softpedia, but first you need Java 5.0 or later. To download SAPGUI, you will have to go here. If you have any problems, please visit https://WEBSMP202.SAP-AG.DE/~sapidp/012002523100008495752016E/, to get more information I think you will find your answer.
