Which is cheaper, buying a branded PC or buillding one?
Hi everyone! I need suggestions on which is cheaper, buying a new PC from a brand such as HP or Dell, or is it cheaper to build your own personal computer by buying different components from the Market? Kindly also suggest me some places where I can buy computer hardware components for cheap. The budget range is around 600$. Suggestions on what to buy would also be appreciated. Thanks.
Best Answer by Ion Hathew
Answered By 0 points N/A #191328
Generally it is cheaper and more practical to buy Computer that is already built or from a reputable dealer and brand. In the sense that you save time and effort. But if in case you could not find a specific model that does not match your needs and requirements you may consider building your own. Otherwise, just modify the computer that comes near to your expectation. Other thing you would like to consider is the response time of after sales service being provided by the dealer or computer store near you. Both brands are respectable so what may differ is the service that they could offer to you locally.
Answered By 0 points N/A #191330
If you visit the online stores you will find many online sellers. They also offer the cash on delivery. So just search the online stores and purchase from them. I am giving the links of a few of them below. Branded are usually cheaper then new. And if you want to make it own yourself, then it will be expensive.
Answered By 0 points N/A #191329
Hello Maria P Gibbs,  Defiantly if you are going in terms of money then you should go to make your PC, Means assemble it for you. But if you want to save time, your efforts and lots of Headache, Then you can buy any computer from a company. My suggestion for you if you go to buy anyone then goes with dell, As it provides manufacturing warranty as well as physical warranty. You can assemble one from any of the available computer shop from your city
