Hi all mobile lovers,
I was using Samsung basic Android mobile, but now it got damaged due to an accident. Now I want to buy a new double sim mobile phone so that I can use dual sim's at a time. Can anyone help me in searching the cheapest Samsung Android double sim mobile phone and provide me the market value also.
Which is the cheapest double sim mobile phone.
Hello Virginia,
I appreciate your taste in going for a Samsung mobile for a dual sim even though there are multiple other local brands which provide more features than the equivalent Samsung models.
Well certainly the cheapest dual sim Android Samsung mobile is the Samsung Galaxy Y Duos. It comes at a price of Rs.6500/-. It has Android version 2.3 installed in it and has a 3.2 inch screen.
You can get the rest of its details regarding its space and pricing here. Well, if you are a little relaxed with your budget then i would advice you to go with Samsung Ace duos. the difference is in screen Size and camera functionalities and comes at Rs.9500/-.
You can get its details here.
     Galaxy Y Duos                                                    Galaxy Ace Duos
