Which computer to buy? Laptop
I am planning to buy a computer. I want to choose either laptop, netbook or notebook. I don't know what is their differences and features.
Can you help me decide which computer to buy?
On the overview, a laptop is sort of a desktop replacement with built-in optical or storage drive that is designed for mobility. A notebook on the other hand, is the same with laptops with a full-sized keyboard and monitor but does not have built-in optical or floppy-disk drives – but has ports when you can connect external drives. A netbook is smaller in size (a screen almost half the size of laptops and notebooks) and like notebooks, only has communication ports. Deciding on whether to buy a netbook, a notebook or a laptop depends entirely on your preferences (do you want a less bulky computer or a more powerful processor?) or on what’s the computer for (work or leisure or both). If you want a less heavy computer than you can carry around but can still offer enough power to carry on work and leisure pursuits – then you might want to check on buying a notebook.
