Greg Lewis
40 points
Posted on - 05/01/2013
Hi there!
I have this document which was originally created in Excel and converted to PDF for sending online. Unfortunately, I have lost the original Excel file and I am only left with the PDF version. Is there a converter from PDF to Excel that I can use to convert the document without distorting the tables that are in the PDF document? Thanks.
Which converter from PDF to Excel is the best?
Hello Greg
Here is how you can do effectively convert pdf to Excel.
If you do not have Adobe Acrobat you need to download it because it is one of the most convenient software for the conversion of PDF files to Excel. Especially when using the recently updated version. This link will help you download it http://get.adobe.com/fr/reader/otherversions/
– Browse and open then pdf file you want to convert by clicking on the ’’File’’ menu;
– Thereafter, click on save as
– Select Microsoft Excel and further Excel document to save your pdf as a Excel file.
Or you can do it online with https://www.pdftoexcelonline.com/ or download the software which has free trials. Very Easy you just need to select the Pdf file you want to convert then click on Convert. It’s all on the site.
