Which is easier between Filemaker Pro and Microsoft access?
I am a computer dummy but need to build a database for a small business.
Please advise.
Which is the best between Filmmaker Pro and Microsoft access?
Please advise.
I have read your problem and a best solution for your problem which I will recommend you is,
This link will helps you, in order to get the result about that which is the best software of file makers.
https://support.filemaker.com/s/answerview?language=en_US&anum=6159
Here you found main points which differentiate between the MS access and file maker.
And also gave you the basic knowledge about these software's and also provide you that which is the features of from what kind of software is.
Because all the persons has their own requirements.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
