Which is faster stream mp3 Chrome download or Firefox?
Which stream mp3 Chrome download, IE or Firefox the fastest and most reliable? Most of my friends are now using Chrome. What do you think?
It really depends on your preference if you what chrome, Firefox or Internet explorer. But based on my experience I use Firefox & chrome the most. Firefox has a lot of add-ons including an mp3 streamer YouTube down loader even an FM radio tuner and more.
Chrome is fast because its main focus is browsing the internet there are add-ons too but it works best without any. You will definitely see the difference when browsing the web when using chrome. On downloading files. This mostly depends on your internet connection speed.
I recommend chrome because it's faster overall.
I hope this helps
Thank you
If you play mp3 online or stream online music, it doesn’t really matter what kind of browser you are using. The speed of the download or the stream doesn’t rely on the kind of browser you have. It all depends on your internet connection. If you are using a wireless internet like for example when using 3G wireless broadband USB stick, the connection here is fast but still depends on the network traffic.
Also when using a wireless internet like 3G you need to have a good signal reception because your connection depends on it. You may also experience lag in the connection if you have a low signal reception. The web browser doesn’t control the speed of the audio stream because its only job is to download and play the music on the page.
It doesn’t limit the speed of the download or the internet connection and relies on the speed of your internet connection. Aside from Google Chrome, the Opera browser is also a Chromium-based web browser. Chromium is the open-source project behind the Google Chrome web browser as well as with the Google Chrome operating system.
Notifications
