Which features allow server to do “resume”
Hi!
Many of the administrator uses the 'resume' option in the server that allows us to download large files, my question is which application features 'resume' in the server?
Hi!
Hi there.
There is a lot of program in the internet that allows you to download large files (e.g movies,photos,music,documents) that you can pause and resume. You can download this application but it depends on you whether you want to subscribe to the full version or trial version of the product.
When subscribing to full version you need to buy it to be able to have a license key.
The best that I can recommend to you is the Internet download manager which allows you to download large files.
But if you already have this program you can try to search for the other program that you think can help you with downloading large files.
