Which file compression agent is the best?
I want to know Which file compression agent is the best one at the moment. Please consider how much memory it uses, and it's performance, I need expert's opinion.
Good day to you,
I would like to share you my experience using compression agent software, Actually  I use these 3 WINRAR, 7 ZIP and POWER ARCHIVER. For me as a long time user of these data great data compressor and extractor, it depends how the format is compressed.Â
If you have RAR format obviously WINRAR works the best. If you have ZIP compressed file 7 ZIP and POWER ARCHIVER works much better than WINRAR. If compression is your concern. They performs very on compressing doubt about it. The developer team behind these amazing software's strives hard to make their Software works its best.Â
About How RAM hungry or Processor intensive these files are will vary according to how heavy the files the are to compress or extract. The heavy the file to compress or extract the higher CPU usage and RAM usage they are going to be.Â
Here's the link to the software the I used to work if you want to try and download them. You may need to pay a little to some of this software.
1.  7 Zip (Free)
2.  RARLAB WinRAR and RAR archiver downloads
3.  Power Archiver
Fire up your system's Task Manager by pressing CTRL + DEL, go to PERFORMANCE tab and examine CPU usage and RAM.
Hope this helps.Â
Compression of files or folders is the pattern of gathering of a file or files to use fewer memory of disk. The File Compression class contains software programs that will file away one’s files and extract file away files in ZIP and RAR files.
There are many File Compression software such as WinRAR, WinZip, and 7-Zip.
Download Link:
WinRAR : https://www.rarlab.com/download.htm
WinZip : http://www.winzip.com/win/en/downwz.html
7.Zip : http://www.7-zip.org/download.html
Thank You………
