Which to focus more Threats or vulnerabilities(network security)
Hi
I am working as a information security professional in a private firm.As a security professional which one i have to focus more:Threats or vulnerabilities? Please need a answer.
Hi
I would help you on the problem that you are having and my answer to your question is “Both”, if you are a security professional you must know that information on your firm is very important and leakage or tampering of information on your firm may cause a serious problem.
So you must need to put up a strong security for you to lessen the threats and vulnerabilities of the system you are having. And having threats on your system may cause large vulnerability on the system. I hope my advice will help you on your job. Have a nice day.
