Which of the following features is are available in Windows XP?
Windows XP has a more stable environment due to reduced reboot scenarios. So there is less crashing of the computer and losing of important files, improved code protection, Encrypting File System with multi-user IP Security, Windows File protection, and preemptive multi-tasking features.
It is reliable and has a higher performance. It has the Windows Firewall and Windows Security Center. It also has the fascinating Hibernate Mode, wherein you will be able to go back to that state before shutting down with all the programs running.
Since this is a Professional Series, it has faster access to the Internet. It also has a registration which disables downloads or pirated versions that downgrade the quality of the software. It has Kerberos and Smart card support. Of course, it has a fresh visual view compared to the older models.
Windows XP has been the most stable Windows version before Windows 7. While it is an old operating system, it's still widely used by many especially in the enterprise environment.
Some of its features include GDI+ graphics subsystem. Improvements to the Start menu and the Taskbar. Faster startup (compared to previous Windows versions, logoff, hibernation, logon and launching of applications. New security features. Improved application compatibility and shims. Kernel enhancements and improvements in power management. Fast user switching, Remote Assistance and Remote Desktop. This and a lot of other features are present in Windows XP.
Thank you. Hope it helps.
Clair june
The following features are available in Windows XP. Networking features that can involve the connection limit and simplification to the Windows XP professional allows you to file sharing connection up to 10 persons simultaneously, while the Windows XP home edition can allow 5 connections only.
The File system Feature in the Windows XP home edition can support the FAT, FAT32, and NTFS in the file system. Then the advantage is the performance increase and the security in the Windows XP can be use NTFS in your file system. The user Interface Features use for determines on the computer is part of a windows based to the domain.Â
Hello Bappyrb,
Some of the notable features in windows XP include the following:
These are just but a few of the features that XP has, it has lot more others.
__
Regards
Lee Hung
