madly madly
Posted on - 03/15/2013
Hi all users,
I am preparing the process map for some projects. I want some page capture software so that the pictures are automatically stored while process starts from one step to another. Can anyone help me in finding some free page capture software so that I can complete my mapping for processes.
Which is the free page capture software.
Hi Madly,
I think you have no need any free page capture software because you can do this by your windows. Here's a button on your keyboard “Print Screen SysRq” or “Prt Scr SysRq” beside “Numlock” or “F12” button. Then open your “Paint” or “MS Word” and press “Ctrl + V”. It is a manual process, you can also do the same thing by a software.
Here a link of page capture software: http://download.cnet.com/ScreenHunter-Free/3000-13633_4-10063246.html
Best of luck
Hello, Madly
Hope you are fine. I can suggest you 5 best page capture software.
Gadwin Print Screen: Gadwin Print Screen sends the screenshot to the image editor .
Screen Grab: ScreenGrab is a free Firefox plugin. It is able to take a screenshot of a whole web page.
Jing: Jing allows you to record your screen, and create videos.
PhotoScape : It is a fun to use photo editor.
FastStone Image Viewer: At a time it is an image viewer, image editor, and also screen capture.
Know more from this site.
Hope you will get your answer.
