Which gadget is more durable?
When it comes to durability, Â is it true that Samsung is a more long-lasting gadget that any others?
There are a lot of Gadgets nowadays are durable that will last for how many years. APPLE, SAMSUNG, SONY, TOSHIBA, ACER and NOKIA are some company are most reliable and durable. If we based some survey, when we tackle about LAPTOP, Director of survey research Mark Kotkin says the survey showed that Gateway’s desktops are less durable compared to Apple’s. Toshiba and Acer laptops were also labeled as reliable and durable gadgets.
If we tackle about the Cellphone, on the TOP are SAMSUNG and APPLE.
Watch this video for drop test of both Cellphone. It shows that Samsung Cellphones are more durable than Apple.
I’m not sure if there is really such a thing as a tough gadget and the durability of the device doesn’t count even if it is the branded one you purchased or a slightly cheaper one but still sounds fine. The life of the device still lies in the hands of the people who will be using it particularly the owner. Even if you buy such an expensive branded model, if you just use the gadget carelessly and doesn’t know how to take care of it, I’m sure it will only last for a couple of months maybe.
But if you buy a much cheaper brand that you think is still good and you know how to take care of it, I’m sure it will have a much longer life than the expensive one. Although the brand of the product still needs to be considered, you will extend its life with proper handling and maintenance.
Hi experts, with great enthusiasm I have read your comments seamlessly which were really helpful and educative. At present, there are many Gadgets which are durable but by interpretation of your comments, I have got the idea that durable is dependent on how I will use the Gadget, carefully or carelessly. However, expensive branded or cheaper branded model does not matter. Only needs proper handling and maintenance. Sharath, your comments are very effective because your suggestions is not only for the gadgets but for the sake of the users also. I’m so very proud of you. Thanks guys for endowing my knowledge as well Techyv.com too for making public this post.
