I want to buy a micromax 3g phone. It is quite cheaper than an iPhone, and is somewhat maybe good as well as what other says. Actually the reason why am I buying a cheaper phone is that the only thing that I want from a phone is its Camera. So I was thinking of a cheap phone with a camera quality nearest to those expensive ones. May I know which has the best camera among all micromax 3g phone?
Which has the best Camera among all Micromax 3g phone?
HI Walsh
here I am providing some phones which can short out your problem for phone with 3g and good camera micromax is the best mobile brand to provide cheap mobiles with good features i am providing you some of the phones with best features and cheap prices .
A51, A25 Smarty, A27, A35.
These are the phones with cheap price and the requirement that you need
Why buy a 3G phone when Micromax has a 4G version like the Micromax Bharat 5 Infinity. The Micromax Bharat 5 Infinity is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on December 2018 measuring 148 x 71 x 10.4 millimeters.
It is available as dual SIM and uses nano-SIM card. It has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1440 pixels screen resolution. It ships with Android 8.1 Oreo (Go edition) powered by 28 nm Mediatek MT6739 chipset, 1.5 GHz Quad-Core Cortex-A53 processor, and PowerVR GE8100 GPU. It supports microSDHC.
It runs on 1 GB RAM with 16 GB internal storage. The primary camera supports 5 megapixels with LED flash and supports 1080p video recording at 30 fps. The secondary camera supports 5 megapixels with LED flash. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 4.1 with A2DP support, GPS with A-GPS support, FM radio with recording support, and microUSB 2.0 with USB On-The-Go support.
It has built-in rear-mounted fingerprint, accelerometer, and proximity sensors. It runs on non-removable Li-Po 5000 mAh battery and available in Lava Red, Rose Gold, and Matte Blue colors.
1....
