Which is router is best in Us Cellular High Speed Internet
For around one year the MOFI3500-3GN was going on and now the 4G appeared. Has the Us Cellular High Speed Internet has shown the best outcome or fails over its previous version?
After carrying out with the 3G router, the result after testing and comparing it with the 4G Us Cellular High Speed Internet is very disappointing. It seems that the new cellular internet user has very limited Wi-Fi range and automatically cuts out itself. With this, most of the people have concluded in favor of 3G router than 4G. Even if cost is considered, the 3G version is cheaper, works with more stability and robustness without getting your net connection auto off. The features of 3G are very much acceptable with its robust working, that people stated recommending it instead of 4G.
