I wanted to a buy a tablet PC which can effectively perform all the functions of a laptop. As there are many choices, I am confused which one I should opt. Can anyone suggest me the best tablet that is suitable for work requirements?
Which is the best tablet that can be bought for work requirements?
The website laptopmag.com which is a part of Tom’s guide has evaluated the leading tablet computers in the market and has rated them according to various factors. The 9.7-inch Apple iPad Pro takes the credit to be the best tablet so far owing to its True Tone display and sleek design.
Almost every app available in the iOS app store is compatible with the device. Its 12-megapixel camera can click great pictures in 4K. It also has an excellent battery life of 10 hours and 53 minutes. You can see several other best-rated tablets on the LaptopMag page.
If you are looking to buy a new tablet maybe for work, you probably want to check the Google Pixel C. The Google Pixel C tablet doesn’t support cellular connection and will not work on any GSM network worldwide. It was announced to the public on October 2015 and released on December 2015. It measures 242 x 179 x 7 millimeters and weighs 517 grams.
No SIM card is supported. It has an LTPS IPS LCD capacitive touchscreen display with 16M colors at 2560 x 1800 pixels screen resolution and supports multi-touch. It runs on Android 6.0.1 Marshmallow upgradable to Android 7.0 Nougat powered by NVIDIA Tegra X1 chipset, Quad Core 1.9 GHz processor, and NVIDIA Maxwell GPU. It doesn’t support microSD.
The Google Pixel C tablet runs on 3 GB RAM with internal storage available in 32 GB and 64 GB capacities. The primary camera supports 8 megapixels featuring f/2.4 and supports video recording. The secondary camera supports 2 megapixels.
It supports 3.5-millimeter jack featuring active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.1 with A2DP support; and USB 3.0 Type-C reversible connector. Stereo FM radio is not supported. It has built-in accelerometer, compass, gyro, and proximity sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on non-removable 34.2 Wh battery.
It is available in silver aluminum color.
