Which key dell instant launch supports for programming?
Which key dell instant launch support? What all options can I program it into? Can I use any other key on the keyboard to respond to those commands?
Hi Elija Hale Jandroo,
I have seen some forum that tackles about dell Instant Launch manager command keys. It may help you in finding the best answer for your concern. I have attached the link below for your reference.
Notebookreview Forum: Map Dell Instant Launcher Manager Command Keys
Hope that it would help you.
You did not mention particular model of Dell which is causing some problem for you that you need to get this utility worker.
But here I am giving you shortcut key which invokes this program on Dell XPS 15.
You should press Fn + F9 to activate instant launch.
Ctr+Fn+ Arrow Keys enables you to increase volume or decrease it.
