Ngumu
Posted on - 11/29/2012
I am developing a mobile software, with touch technology, which enables users to switch between various games. I need advice on which language to implement 8 ball pool line drawing tool for best results.
Please help.
Which language implements mobile 8 ball pool line drawing tool?
Hello Ngumu,
Don't Worry about your problem,
If you want a best result in 8 ball pool drawing tool.
Then select Espanol Deutsch Francais and chinces,
Deutsch and Espanol is best for 8 drawing tool.
I hope follow its very useful for you,
Thanks,
Shazia Qasim
If you want to built apps for any platform then you will need the SDK for that OS like if you want to make a program for android then you will need and Android SDK and for iOS an iOS SDK is required and so on.
You will also have to learn high level language for that like java or python etc.
You can get android SDK from here and iOS SDK from here.
I hope you find this helpful.
Peter franklin
