Which laptop is good to use?
 Im planning to buy a new laptop and am thinking if what is the best to choose,is it the I series ? any suggestions?
It really depends on what are you planning to do with that laptop. If you buy it so you can play PC Games on it, then the best out there is AlienWare. The most reliable laptop is Dell, the price is a little bit higher but the quality is there. So you pay good money but for good quality. If you want cheaper laptops but overall good quality you should go with HP or MSI. My personal opinion is that you should avoid the low end brands like Asus, Acer and other notebooks like that. Or if you are a fan you should go with a Mac.
