Which laptop should I buy please suggest me
I am a school teacher and to access internet, ms office, and other such basic software’s I need a laptop with following configurations. P4 2.4GHZ 512 MB DDR 400MHZ DVD writer -R/+R 17"display And a good Graphics card Please tell model and Price. Which one is better a tablet or laptop or these basic uses.
Answered By 0 points N/A #178174
If you want a device just for browsing the internet and occasional document oriented actions, then i would recommend a low budget tablet that will do the right job for you. Buying a laptop with those specifications is not profitable, but finding a cheap tablet with higher specs than that, then yes, i recommend a tablet made by Microsoft that uses the Windows 8.1 operating system.
Lenovo Miix 2 Touchscreen Tablet : this an 8 inch tablet with the Windows 8.1 operating system installed on it. Its battery lasts up to 10 hours, much more than a laptop. It has a multi-touch display and it comes preloaded with the Microsoft Office Home & Student 2013 (for editing and viewing any kind of Office files). It's powered by an quad-core Intel Atom processor and 2 GB of RAM so that you will never experience system freezes or occasional stutters during its use.
Choosing a tablet over a laptop also brings a lot of other advantages like portability, bigger battery life and the ability to take your work wherever you need to without thinking about plugging it in a socket for a recharge.
