GC2012
Posted on - 06/09/2012
I have to write articles several times.Which should be the latest and no copy paste job.So I need to know which is the latest and most effective quality assurance software for Article writing?
Which is the latest quality assurance software for Articles?
Hello, I have looked at your problem and according to my research I think IBS might be the best software to provide Complete Quality Assurance for an article writer like you. It manages your requirements, bugs, tests and issues. It has user-friendly options to make analysis and it makes it easy to track data, identify a problem and propose long term solutions. You should give it a try and see if it meets all your needs. Other alternatives include Spiratest, QSYS professional IG/OG softwares. To get more information however you can contact IBS America or you could also visit their website i.e. info.ibs-us.com. Hope this helped and good luck in your writing.
