Can somebody please tell me which is the latest version of Raxco Perfectdisk RX suite?
Raxco's latest PerfectDisk RX suite comprises a durable disk optimizer as well as a registry cleaner.
Subsequently messing with the registry can generate numerous problems as it resolves, the software lets you to back up whatever you delete with it.
PerfectDisk Rx Suit also performs the more precarious operation of abolishing duplicate files.
So please tell me the latest version of Raxco Perfectdisk RX suite.
Which is the latest version of Raxco Perfectdisk RX suite?
Hi Taylor Anderson,
I have accessed the producer's blog site to view their latest version of the perfect disk Rx suite and it seems like they are on version 9 and still developing the product.
It is true that it can optimize your virtual disks to maximum performance but as far as I know, when you drive old enough, the performance will be slow as you expect and sometimes, software can't help to optimize the hardware's current state, it may also be the cause of damage, think about it.
How are you doing?
Hope all is well with you. PerfectDisk Build 11.00.170 is the latest release of Raxco PerfectDisk RX Suite.
It was released on Fourth of July 2010. It was added a feature that allows shutting down after a manually initiated defragmentation pass. In the previous version this feature existed only for schedules.
Download it for free on this site
