kent woods
30 points
Posted on - 03/22/2013
I want to convert a PowerPoint presentation into video. I saw that leawo has many kinds of converters. Which converter should I download, to be able to open my presentation on several types of computers?
Thank you
Which leawo converter should I download?
Hello
There is no need to use any additional software to convert PowerPoint presentation into video, you can use Office. To do that follow there instructions:
Create your presentation, add images or narration as necessary and save it.
Now go to File and click Save and Send
Now you'll see dialog and in that dialog click on Create a Video
Select what kind of video you need, depending on type of your presentation select one of presets
Click Create video button
Select location where you want to save it and you are done
Regards.
Leawo PowerPoint to Video Pro will suit your needs. This can convert your PowerPoint to almost all video formats and compatible with almost all PowerPoint versions. You can try it free or purchase it for $44.95. Download and install it from the link below:
http://www.leawo.com/powerpoint-video-converter/
