Which lumbai version should i buy?
i am confused I am looking for good browsing. Which lumia version should i buy?
Best Answer by Las Lenen
Answered By 0 points N/A #162951
Dear Gabrio,
If you are looking for big screen handset lumbia 900 is best for you. But if you compare all the handset then you should choose 610. The Lumia 610’s back, home and search buttons are touch-sensitive, which we prefer to the 710’s physical the same five-megapixel model as the 710 buttons.
The camera is fairly average ; there’s not a great deal of detail, and noise speckles are present even in every shots. Compare it with Windows Phone handsets, then you will find out that it ' s little slow, but it is  still faster than  Android handsets I have come across.
