Hi guys
Is there the best memory manager droid that will free up as needed or any other solutions I could apply. Actually I have installed a memory manager and its appear to be working but my problem is that since I installed, my memory of phone continuously crashed. Means when I go to send my SMS or phone calls, all I see just phone numbers not names. please help me
Which memory manager is the best memory manager droid for nokia mobiles
Seems that the application for memory management is poorly written and that is causing the memory to failure, causing problems to your mobile phone. I would recommend using Auto Memory Management Premium, is one of the best memory management applications for androids and it will not cause you any problems. You can find it in the Google play store though its not free
Regards
Hello Joseph Bankk,
Maybe that memory manager is not compatible with your device. Better if you had mentioned your Mobile model. As you phone has been continuously crashing, uninstall the memory manager and try Auto memory manager. It has a large piece of customization. It has an option named auto kill, so if you just forget to kill apps, it will be automatically done by the app itself. Now it has a good rating at PC MAG and is in the list of top 100 apps. Just try this app and see if it is solved.
Here is the playstore link.
Hope it helps!
